77 35hp johnson backfireing?
luisdeleon
well guys i finally got it started.so happy, but i noticed it back fired a bit when i give it gas, anyone have an idea what it can be? the engine sat for a while, i rebuilt the fuel pump but not the carb. and does this engine have a fixed timing on it like the jet ski two strokes? could that be of?
thanks
luis
luisdeleon
Re: 77 35hp johnson backfireing?
thanks you i'll try that tommarrow when i get home from work. hopefully it still lite outside.
luisdeleon
well i finally had a chance to work on it some more. i did the adjusted screw thing and no luck still back fires a bit, very mild but does pop. anyone have any ideas. it starts right up runs but pops a bit.
thanks
luis
HighTrim
Spitting back, sounding like a mild backfire, indicates a carb slow speed restricted jet..... something causing a lean carburetor scenario.
luisdeleon
thats what i tried to adjust, was the lean- rich screw but had no effect, still kept on doing it
