'77 70 hp johnson
boatdumb
can anyone tell me what the rectangular shaped cover is covering on the starter side of the motor? it is towards the back of the motor it is about as tall as the motor. <br /><br />thanks <br /><br />baotdumb
R.Johnson
Re: '77 70 hp johnson
This is the exhaust by-pass cover. It covers the exhaust ports.
boatdumb
R.Johnson<br />do you know if water can come through there into the head if the gasket is bad?
boatdumb
the reason i ask is in hopes that my head or the cylinder wall is not cracked. I just put a new head gasket in and noticed water seeping out around there now and i'm still getting water in the head.
ob
boatdumb,In short,yes,a leaking exhaust cover gasket can introduce water into the cylinder.If you're confident that the head cover gasket and sealing surface is clean and torqued,and the cylinders are showing good compression,the exhaust cover gasket(s) is a likely source of your problem.
boatdumb
thanks OB i think i can sleep now. i'll pick up an exahust gasket tomorrow and try that out. i can't wait till everything is fixed. seems like i should have bought a new boat for my first one. i'll know better next time. i'll also know how to fix everything on it if i do have a problem haha.<br /><br />thanks :)
