iwombat
- Joined
- Jul 12, 2006
- 3,767
'77 85hp - Update and confusion
Well, I've got the carbs off and they're ready to get all sklorbed out. In the meantime I'm looking at the block and thinking hey, I'm basically a handfull of bolts away from opening the crank. So, I'm thinking I may just do a ring-job while I'm staring it in the face. Compression is still hovering around 90psi after de-carb.
Is it a simple to tear the rest of it down as it looks? Looks like the intake manifold should come off as a unit, as well as the lower part of the crankcase. I'm hoping the latter comes apart with all the various linkages attached. The parts list I'm looking at is:
1 - manifold to crankcase gasket
1 - seal cylinder to crankcase port
4 - retainer set (aka big-end rod bearings)
4 - std ring sets
2 - head gaskets
That look about right?
4 - std ring sets
2 - head gaskets
