77 Century Arabian - finally...
joenapier
After over a year of dry dock (my garage), this 1977 Century Arabian finally gets wet!
Thanks to my friend Seagrunt for the help along the way. Also thanks to the forum community - I've asked a few questions myself but I really spent hours and hours trolling these boards for some wisdom. I still learned the hard way a few times.
Special thanks to Charlie, my 3 (and now 4) year old that was out there with me every week - usually until his bed time. He is the only 3 year old I know tha can use a drill (without a bit - wink wink) and a multimeter (checks continuity for me). I never knew a kid that liked to work like Charlie does.
I bought it out of Indiana in 2008 and I knew I had some work to do. With 300 hours on the merc 260 (HP, that is - its a chevy 350 underneath), I thought - how bad can it be? I brought it to Charleston SC and the more I dug into the floor, the more wet foam and rotton wood I found. You know how projects go - once you get started, you can't do it half way because, what's the point? Man, I wish I had more "before" pics.
From the Hull up. I took it down to the stringers (which looked good under the glass) and built a new floor, glassed and foamed. The rot went all the way up to the captain seats. Also, I jacked up the motor, removed the rusty motor mounts and the rotton wood under them. I replaced the skids under the motor mounts by building fiberglass shells and then filling with Seacast (yucky stuff but very strong).
Seating. I liked the old front seats except the headrests had to go. I sent the seats to be recovered. Then I built the back bench seat and pushed it back about 8 inches for more room (my apologies to the purists - I did not always stick with the original). Then the kitty cat deck was built a bit smaller. Bench and deck sent to upholsterers.
Paint. It had been painted before (rough) so I sanded it down down down to the gelcoat. I primed it twice, wet sanding between. Then Interlux Brightsides roll and tip and roll and tip and roll and tip. Finsh turned out nice once I learned to time the operation and stay ahead of the tacky surface.
Chrome and stainless. All removed and polished / cleaned, including ss rubrail and windshield.
Wood. I built new foredeck, back bench, side steps, floor hold covers, dash, glovebox and some other wood accents out of Ipe wood. Very nice alternative to teak. Keep it oiled and it stays beautiful (wear respirator when working with Ipe - the dust is a bad irritant).
Windshield. I shortened up the side windows so I was not so surrounded by so much glass. Now I can put my arm on the gunnel as I drive.
I've replaced the stern drive impeller and I am glad I did - several of the blades looked pretty bad. After I did, the engine temp dropped 25 degrees. I re-aligned the motor (needed to because I replaced the motor mounts).
I turned the key a month or so ago and I had a short somewhere - dang. I found that the oil pressure gauge was shorted through (how does that happen?) and then...still no start. Then I traced it down to the neutral safety switch in the remote throttle shifter. Then, it started great after a ear being dead.
We took it out two weekends ago for some very short and easy runs up Hobcaw creek. So far so good. The Blue Angles were in town last weekend and we opened it up on the Charleston Harbor and it does great!
Again - thanks to everyone that gave me a lot of help - whether you are aware you did or not! Thanks.
joenapier
Re: 77 Century Arabian - finally...
more pics
joenapier
again
joenapier
again again
joenapier
again again again
joenapier
finally
captmello
Nice Job. I love those old Centurys.
Good idea having the Kid do the grinding for you, saves on the itching.;)
Pics are a little tough to see, but...
Good luck with it.
tschmidty
Nice looking boat and looks like you did a great job with it.
mcrustyruss
Nice job Joe! I just started tearing into a 74 Arabian yesterday that needs a LOT of work! Your pics were very inspirational. In addition to the great job you guys did, I wanted to compliment you on the invaluable lessons you probably passed on to your helper. I've got 3 boys and a girl. The oldest is only 5-1/2! I had to sell our first Century, but now I've got a chance to make them learn to respect things that only come thru hard work. I'm going to post what I've got so far. Take care and enjoy that great looking boat!
79arabian
I just got onto this site and I want to let you know your Arabian looks great.
I just finished a total resto on a 77Arabian 200 last year.
Your pictures remind me of the same issues. Rotten floors stringers, bad engine etc.I almost gave up at one point as everything I looked into just got worse.
To make a VERY long story short, I tore my boat down to the bare hull.
New stringers ,engine supports, transom, foam floors. all wood was double epoxy coated. Engine was a total blue print type rebuild. all new interior and paint . Too much not listed.
These are beautiful boats and nothing sounds as good.
I will send you pictures if you give me your email.
Great looking boat!
Great looking boat!
Just started a rebuild on a 1974 Century Mark II. I would love to see how you rear engine compartment is constructed. The Mark has three plywood cushions that span the compartment. I was hoping on getting some ideas on how to rebuild this.
When you stand on them they don't give you a solid feeling especially after they are in the weather
