I have a quick question, I am in the process of putting the lower unit back on this motor. I was lining everything up, and I was turning the prop shaft to line up the teeth in prop rod with the motor, Once I had the teeth lined up, I began to push the lower unit into motor. For some add reason now the prop shaft spins freely without spinning the prop rod so I remove the lower unit, and now I can spin the prop shaft but the prop rod won't spin. Its like it disengaged, did I do something wrong, or can the lower unit be disengaged.
Thanks
mav6759
Thanks
mav6759
