Inherited this engine after sitting dry for 12 years. Told it ran very well when put up and covered. It starts instantly and runs up fine, even idles but misses and pops on occassion and smokes. Smells very rich. The upper of the two plugs gets very wet. I have not done a compression check. does the fuel pump run off vacuum from the upper cylinder? any help would be appreciated. oh, I have adjusted the mixture down but doesnt change the wetness. 77 evinrude 35, electric. one other thing. exhausts water, but spits very little from the side. is this normal?<br />Dan
