Is it cracked? doesnt make sense unless its cracked. the bowl is on the bottom and fuel goes through the jet and into the carb and then into the engine:facepalm:
Fuel running out the atmospheric vent suggests the needle isn't seating. The orange 'duckbill' fuel pump element can also split and allow onboard tank drainage of fuel. You goyya rebuild the carb, and thoroughly clean it up.
