77 johnson 115 part availability
old geezer
Anyone have a thought about rebuilding a 77 johnson 115 hp 4 cyl.
That is, parts availability, and is this an easy motor to work on?
I am handy, have tools and time, and a manual. Never done an outboard motor before. Rebuilt lots of truck related stuff as a hobby in the past.
Does this motor use a lot of gas?
Its on an old fiberglass boat I bought, used in salt water, but does not look too corroded from the outside. Thanks Retired old geezer
ezeke
Re: 77 johnson 115 part availability
The 1977 is the last in the line of 115 V4 motors from 1973-1977.
In 1978 the 115 changes gearcase, ignition system, exhaust, water pump, flywheel, tilt & trim, transom mount, shift rod, etc. You name it, it probably changed in 1978.
I keep a 135 and 115 running from that series and most parts are either available from my local dealer or from sea-way .com in Seattle, WA.
It is fairly cheap & easy to find a parts motor, and I would highly recommend that. The Factory Service Manual for 1976 or 1977, either Johnson or Evinrude will be necessary. There is almost always a used one on Ebay.
For example, Check Ebay now, search for 160199758747 or 260203497839.
Wide open and under load, expect the motor to use around 10-11 gallons per hour, half that at cruising speed. There is little relief from that fuel consumption in newer motors, despite the hype.
The parts manual is on-line at the BRP site, you may want to take the time to download it.
http://epc.brp.com/default.aspx?brands=ej&lang=e
old geezer
Thanks
Gives me something to ponder. Might put the motor on Ebay for sale, so someone else can use it. Old geezer
