'77 Johnson 70 hp coils
Lrdrlker
My 70 horse Johnson is running rough...misfiring and difficult to stay running and get into drive gear. When it does go into gear it WILL get up on plain but it is a VERY slow and steady acceleration. I was thinking that I should check my coils so I pulled them off and checked them with my Fluke multimeter. They read 1260, 1260 and 1350 each. What confuses me is the chart says that they should be between 200-400 ohms. The readings on my meter are pretty consistent! But, if I go by the chart they are ALL BAD! It's too much of a coincidence that the actual readings are so tight together! What do I go by? Any advice will be greatly appreciated! CheersScreenshot_20210712-183603.png20210713_070453.jpg
Crosbyman
as per the other post ... poking the plug boots to ground will tell you 1250 ohms or so and that is ok for IGNITION COILS.....
