Re: '77 Johnson 85 Javalin steering locked
Got a 70 HP 1976 Johnson with some teleflex cable jam tilt tube locked.
The boat sat all winter this year and got rusted up, could not move it one bit. Whacked it a few times, jerked the steering wheel, all of which did not work.
Heated the port side of the transom bracket enough to make lil gap to spray into. I used knocker ? technician grade. Had to heat it early in the morning so that it was cold enough for the cable to stay cold and the bracket heated up nice.
Then I waited and thought and researched then the guy I bought the boat off of told me to
1) remove the grease fittings on the bracket, spray BP Blaster, Knocker something int o the fittings
2) heat the tilt tube in the center and towards port a lil bit.
3) Spray immediately after heating so it seeps in.
4) wait
5) Spray again
6) beat on the port side of the steering cable with a 2x4 like you just lost you mind.
7) Rinse and Repeat
Worked for me, the only thing in all the posts I have read on this site and many others regarding this issue is Step #1 - REMOVE THE GREASE FITTINGs TO SPRAY IN SOME PB BLASTER.
Going back to stabbin in the cabin,
