77 Johnson 85hp Part and Info Help.
pjenewei
I’m looking for a 1977 Johnson engine cover latch for the right side, Anyone have any suggestions where I could find it. Also can anyone tell me what the proper oil mixture is for this motor, hard to start but runs great after it starts. Thanks for your help!
ob
Re: 77 Johnson 85hp Part and Info Help.
50:1 mix .Are you priming and choking engine properly on startup?If so,try replacing sparkplugs .Local shop may have a used latch for motor cowling.
pjenewei
Can you tell me what the correct starting procedure is for a 77 Johnson 85HP. Thanks for your help!
