'77 Johnson 9.9 Idle Problem
StressedOut
'77 Johnson 9.9. Engine won't idle. Cleaned Carb and found some gunk - seems to be clean now. Starts easy but still won't idle normally. When I try to idle, sounds like someone hit stop button. Pulling out choke fast and push back in will keep engine running. Looking for possible fixes - clean carb again ?, possible fuel pump or fuel line ?(removed fuel line, manually turned over and seems to squirt ok), vaccum leak somewhere? new plastic fuel tank and hose - perhaps leaking? Have manual ordered but looking for tips from you experts ... thanks
DHPMARINE
Re: '77 Johnson 9.9 Idle Problem
Sounds like it's still the carb.Did you install a kit,or just clean ?<br /><br />I suggest the kit,and remove /replace the core plug over the idle pocket,so the idle passages get real clean.<br /><br />DHP
StressedOut
Just cleaned the carb.. I have new carb kit but awaiting for the '77 Johnson manual to arrive. Replacing the core plug sounds like a good idea ... need manual before I attempt anything furthur than general cleaning ... don't want to wind up with a "box-o-parts" ... Float seems to be properly adjusted as per Seloc manual ... OMC manual shoudl arrive today. If you follow this post, will keep it updated. thanks for all suggesstions :)
pgdignan
Stressed,
Certainly no expert on these matters, BUT I just went through something similar on my motor. In addition to pulling the plug out and cleaning the ports, make sure the jet (don't know if it's a main or idle or if they're one in the same) is clean. Mine had three little holes in the side of the jet that were plugged (very small holes) when I cleaned it with air and carb cleaner it didn't get those little holes clear, had to clear them with a stand of copper wire. Wish you luck with it.
Pat
Solittle
When you think it is real clean blow out all passages with high pressure compressed air - no rattle cans.
