Just purchased a 1977 cruisers with an omc 190hp. Ran perfect first time out earlier in the week. Today different story... Under load has a backfire through the carb and boat almost shuts off not like only one cylinder is missing. Points condenser cap rotor plugs wires and fuel filter are all new. Firing order is correct points set to .017. Idles great will rev up no problem out of gear and in water but under load above 1500 rpm will start to backfire. Thinking ignition related but not sure where to start. Also thinking (hoping) if it was valve train issue ie cam lobe burnt valve ect I would have issue load or no load. Any ideas would be great!!
