77GALAXIE
- Joined
- May 20, 2009
- 22
My Volvo Penta 4 cyl. is overheating rather quick. To add to the maddness I have water in my oil which looks like a vanilla shake under the valve cover. But after I removed the valve body and looked at the condition of the head gasket I noticed the oil in the block didnt look corrupted. I didnt see any signs of blow by on the head or the gasket but I am getting water from somewhere. I turned my attention to the pump impeller. It is in great shape but where it links to the block the rubber guild was cracked and it looks like water is getting by. The housing that the pump and pully for the altenator mount to ; Is water not suppose to get in there. If so I am thinking my upper and lower seals could be bad where the crank shaft is mounted. The block is steel and the portion the pump mounts to is aluminium. I trying to issolate the problem and any help would be great. Is there an ideal site for parts on a 1977. Local dealers here have been no help at all. Thanks
