78 115 Evinrude card assembly question
ToolMaster
I just got the rebuild kits for my 78 rude 115, this will be my first time rebuilding carburetors, and they did not have the manual there at the shop, so I was wondering if anyone has the assembly diagram to help me out along with the process?<br /><br />Thanks in advance<br />~Steve
DHPMARINE
Re: 78 115 Evinrude card assembly question
ToolMaster Basically you are replacing parts,gaskets etc.When you install the new needle,seat,gasket and float,turn the carb upside down,and be sure it is parallel with the carb body.There is a float drop spec that I do not have here,but very seldom is it a problem.Run a small wire thru all the passages after soaking in solvent to be sure they are clear.<br />DHP
