Re: 78 200 20hp electrical or timing?
I would suggest seeing if you can repair the wire some how
If not, check ebay.
Also my one engine I setup the remote control is a 1977
possible your missing the remote brackets...
post up some pictures of the tiller handle side of the engine.
on that side should be for the throttle, and on the other side where the shifter is, there should be a bracket that can accept the plastic cable end.
When I first got my engine I made my own controls with a random cable buy at the marine store, and used stainless wire to attach the cables...
it worked fine, but when I finally saw how it was supposed to mount It was all backwards from the way that made most sense to me.
if needed I'll get some full resolution pictures posted (as a link)
Note that the engine is currently in storage, and the cables are not connected...
