I have a 78 Johnson 200 and was curious to know the effects of updating the carbs to the primer choke system with a type III carb versus the butterfly choke system and the type II Carb. Is there a notable advantage in having the intermediate orifice? I was also wondering what the effects of using a carb with 1 3/8 throats vs the current carbs at 1 5/16 throat? <br /><br />Currently when I put down the throttle on my 19ft it hits a dead spot and then takes off if it doesn't die. The engine idles fine and runs fine at full throtle. I'd like to know if the intermediate jet/orifice would help with this?<br /><br />Looking in a book it looks like they went to a type III in 1979 and kept that type until 1983. Curious to note that the 200hp was then gone for two years, and then the CU IN displacement changes to a larger number when it came back. I suppose that was due to where the horse power was rated from?<br /><br />Another question is concerning the advance. I have read discussions where it suggests advancing the timing 1 degree for every 3,000 feet in elevation. Is there any truth to this?<br /><br />Thanks in advance,<br /><br />Matt
