Re: 78 70hp evenrude cooked
I am sure others will have more advice for you, but my suggestion at this time would be to drop the lower unit again, remove the thermostat cover and thermostat, and stick a garden hose in the hole and back flush the system. Something could have gotten lodged up in there, and also replace the thermostat while you are in there. It sort of sounds like something is wrong with it if it flows at first but then stops, either that or there is something causing a blockage.
