Hello, first off thanks for any help I may get. I've looked into my problem and searched around but I'm not sure if I am performing the tests right.
Let me back up a little, I have no spark on my top cylinder, after replacing the coil, powerpack, and rectifier, still no spark. That left the stator and/or timer base. I'm trying to bench test these with a fluke 179. I have a basic understanding of how this meter works, and have seen values all over the map online for the stator and timer base.
FWIW My garage mechanic said that its highly unlikely that a bad stator would only effect one coil so I haven't tested the stator as of yet.
What I found on the timer base is that any of the sensor wires when tested to the black ground all come back around 8 ohms. Would this be considered weak and needing replacement? I also messed around a bit and when I put the base back inside the flywheel and spin it the reading will spike to around 15-20 ohms, again not sure if this is considered within spec, or just inconsequential. I also see values for DVA listed, is my meter capable of taking these values? Do the parts need to be hooked back up to the powerpack and the engine cranked to test them?
Just to add a little more spice to this post, upon removing the flywheel I inspected the taper and found it to be pitted from where the sheared/smeared key was, along with the keyway on the flywheel being slightly deformed, just enough that it wont accept the new key. I figure I can touch the keyway up some to allow the key to seat tightly without mucking up the keyway any more. I've read conflicting reports on using valve lapping compound on the flywheel and crankshaft, but I doubt I'll be able to completely remove the pitting with the lapping compound alone. Other sources online said to not lap them, and to instead use loctite (either red or blue) on the taper and torque to spec. Which is the best idea, outside of buying a used flywheel (last resort for an engine this old).
Before anyone asks, I have corrected the problem which caused the flywheel key to shear in the first place. Which was a blown exhaust manifold gasket caused by a slightly warped manifold plate, caused by the engine overheating, caused by a blown impeller, all fixed now (do I get my outboard tech certification yet?! lol), just need to correct this ignition issue and get it back on the water!
Thanks again for any help!
