fireman57
- Joined
- Aug 24, 2004
- 3,811
Engine was totally submerged for 36 hours. Got it home and cleared everything out. Not the first time I have had to resurrect one. Compression 120 all four cylinders. All the grounds had corroded off so replaced all of them. Cleared all fuel lines and blew out carbs.Took starter apart and cleaned it. New solenoid and had to replace a powerpack and put new Champion plugs in. Fuel pump was cleared and is okay. Spark jumps a good 7/16th inch and bright blue.
Got her fired up and there is a miss in there somewhere I can't find. Bottom carb was leaking and I could not get it to seal so got a kit and rebuilt the whole thing. Welch plugs and all. Blew out with compressor like always. Fired right up and ran nice. It was idling faster on the muffs than before and no shaking so I thought I had it.. Shut it off and called the missus out to hear it and when I fired it up again it had the miss and the shake again.
Engine was not running when it sunk and both carbs suck air good, nothing in the reed valves, and all fresh fuel. Carb bowls are both full.What the heck am I missing?
