Picked up a '78 90hp 6 cyl and having a few fuel system related problems, have some questions:
1. My fuel pump o-ring (above the fuel screen) doesn't look like it fits properly .. it's quite a bit larger than the screen diameter and I need to push it into place with a screwdriver (thinking this is a dirty fuel / ethanol issue). Does the 90hp use the same fuel pump as the 115? I can't seem to find any o-rings listed for the 90hp.
2. I've 10 gallons of premium gas with about 6 oz of Seafoam per 5 gallons. In general, the motor is running much better, but I do get some instances when the top carb spits fuel out and the engine bogs during acceleration. Is this a sticking float, and how do I fix?
3. Any other tips for fuel system maintenance outside of removing and rebuild carbs?
4. Is the fuel pump filter the only filter in the fuel system, and should I add a filter somewhere else?
