So I've been reading up on water path and poppet valves and have a couple of questions. The way my motor is set up, and correctly according to the Merc manual, is to run my port t-stat to the starboard t-stat which then runs down and directly connects to the poppet. The telltale is supplied by a link coming out of the block on the port side and is not plumbed into the t-stat discharges at all.
So here's my question. If the poppet doesn't open until higher pressure, how does the water that's exiting the t-stats, and cooling the motor for that matter, actually circulate? According to the flow diagram the telltale is supplied by water that's actually circulating, ie water that has actually passed through the poppet. Thus, when no water is passing through, no water out of tell tale.
I'm alarmed because when I run my motor on muffs the heads get hot pretty quickly and the only water I'm seeing exiting around the prop is cold. No water comes out of exhaust relief ports and none is coming out of my tell tale. If I pull the hose running from the starboard t-stat to the poppet and just allow it to flow I get a lot of hot water and my heads stay cooler. This tells me there's a problem with the poppet but I've rebuilt all components in there and haven't seen any improvement.
Reading the forums it looks like a lot of people advocate plumbing the t-stat discharge into the tell tale and a lot of people also advocate supplying the poppet from the plug on the top of the block (behind flywheel). If I did that, where would I run the water that's exiting my t-stats?
I think it's currently plumbed as it's supposed to be but I don't see how it can function in this configuration. Please help my out as it's got me scratching my head.
