Well OK here is what I've done first day I messed with it I turned it over checking spark. I had spark on 2,3,4, not 1. Motor would crank and run but rough and that is obvious. Put a different coil that I know was good and same thing fire on 2,3,4 not 1. Then checking wires plugs all that for loose connection, try again now Firing on 2,4 not 1,3 hmmm! scratch head. Then I swapped rectifier with one I am pretty sure is OK no change. Then I tried the swap the brown, brown/yellow wires from the stator from one side to the other. It moved the spark to the other side replaced Stator with one I think is good. Now back to the beginning. Everything is now back to where I started firing on 2,3,4 not 1 hmmm! So now I try swapping the power packs stays the same. Also tried unplugging the big plug(black/yellow wire on both power packs then no fireat all. I have ordered a DVA adapter. Is is possible that my problem is the trigger/timer base. I just don't have fire on number 1.
