78 evinrude 150 outboard idle adjustment question
brianis
so was having idle issues so I cleaned the jets and 2 of them were plugged so now where is the idle adjustment and how many rpm's should it be running seems like there are two cables running to the motor the lower I found out adjusts the linkage for the trans. And what should the rpm be at if im adjusting on muffs it just doesn't seem to like to run at idleIMG_0341.jpgnot sure if you can see it theres that upper and there is a lower linkage
