My 1978 Johnson 35 is having some problems. When cold, it starts well under choke, and it will run without choke very quickly. When accelerating, sometimes there is significant hesitation. When warm (after at least 15 minutes) the motor WILL NOT accelerate, it simply stalls if you try to open the throttle. In fact, the motor will barely run at all, unless choked, when it runs a little. We recently replaced the fuel pump, and the plugs are new as well. I am thinking that the problem is carb related. What are your thoughts?<br /><br />Thanks in advance!
