EclecticNeophyte
- Joined
- Jun 17, 2017
- 31
I have a 1978 Merc outboard model 200 (ser# 4954879), that's rough at idle, runs great at mid-throttle, but dies after 15 to 20 seconds once reaching full throttle (hope that makes sense). I can re-start, but the last time it did this, it was a struggle to get it fired up again. The carburetor and fuel pump are integrated, and I plan to rebuild both.
I've checked the coils and plug wires as best I know how, by taking continuity readings with a digital multimeter. The coils checked ~ 990 and 1000 ohms between high voltage and ground, and zero between + and - terminals. Plug wires were solid zero ohms.
The plug in the top cylinder was pretty oily/dirty but other than that looked ok. The bottom plug was pretty clean.
I rebuilt the water pump, cleaned the discharge tube and the motor pee's a solid steady stream even at an idle.
The gas tank, hose and primer bulb, etc., are only a few weeks old. I've made certain the vent is open, but the motor still dies at full throttle. Not a lot of coughing, sputtering, etc.. the RPM's simply fall off, then eventually dies.
Once I get it going again, it runs fine as long as I don't try to max it out...
Am I on the correct path thinking this is a carb/fuel pump issue, or are there other things I should look into? I've read through the Clymer repair manual, and while it has very good 'how to' info, it's not much help in the trouble shooting dept. (no symptoms >> check this ).
Thanks, and apologies if this is a frequent question. I searched the forum, but didn't find a similar thread.
-Vern
-Kennewick, WA
-Vern
-Kennewick, WA
