Hello,
I have a 78' mercury inline 6 115. This boat runs great with new plugs, a true monster. However, after only a few hours of running, such as two 2 hour trips, the plugs begin to foul and the boat stuters and fouls when trying to plane out, obviously not allowing me to plane. I have decided that it may be a ignition issue, maybe? Maybe there is a weak spark, so i have begun to clean the cap and rotor, removing the corosion that could be the problem. However, could this also be a fuel problem? Maybe a float adjustment, if so how would i go about adjusting the float levels? I have tried ever mixture setting known to man, running 50:1 gas to oil. Over the past few months I have rebuilt the carbs, fuel pump, replaced bulb, new plugs and fuel lines. Any ideas?
