78 Mercury no spark in #2 cyl
Druther
I have a 1978 Mercury Outboard 4 cyl serial # 4835879T. I am getting no spark in #2 cyl. Would that be the coil?
Laddies
Banned
Re: 78 Mercury no spark in #2 cyl
You either have a bad coil or switchbox, just cross input wires on 2 coils if the problem stays on the same cyl. its the coil if it changes cyls. its the box.
HP who cares???
Chris1956
Laddies, An inline six of that year has distributor ignition and the likely suspect would be the spark plug wire, rather than the coil.
Faztbullet
Do as Laddies posted....if its a bad trigger you will lose 2 cylinders, one cylinder is usually a switchbox as I have see very few freshwater coils go bad.
hotrod53
Pull all of your plug wires and measure resistance from the cap to ground, mine were about 1100 ohms each. Then remove the input wire to the terminal on the coil and measure that to ground, it will have little resistance. Measure each plug wire from cap to plug, the plug wires pop into the coil but they are tight. If you find a difference in comparing the test readings, you will have diagnosed a bad coil or a bad wire.
If you do have a bad plug wire, do not run it. The field created in the coil has to go somewhere, if it isn't connected to the spark plug, it will find it's way to ground thru the side of the coil. Coils do go bad, my #3 went due to a broken wire caused by a careless mechanic yanking on the wire to change plugs.
There are at least two different coils used on those motors, a cheaper one ($25) and a more expensive one ($65) ... guess which one mine used ...LOL, and they aren't interchangable. They changed the part number on the more expensive one so research will be in order.
Faztbullet
Thats not the coils fault it failed :D its the dummy that yanked wire!!!!
hotrod53
Yeh .... and I paid that numb-nut too!
