Re: 78 rude 140 v4 driveshaft change.
Dave,I can't find your other post.<br /><br />Basicaly drop the drive,remove the waterpump stuff,the upper driveshaft bearing housing.Remove the prop shaft bearing carrier.Remove the pinion gear nut and the gear,remove drive shaft and reassemble with new pinion nut and wpi.<br /><br />In a shop,the new shaft needs to be shimmed properly in a special tool.Also while apart all seals and gaskets would be replaced.<br /><br />DHP
