78 Tower of Power no spark issue...
Nebraskan
Hey guys, just got back to the states (Nebraska!!) a bit ago from indonesia where I live and ended up taking on a project for a family friend. Was going to be fun I thought haha, still is, just chasing gremlins like crazy and now hit another one that I haven't been able to figure out and I've been researching the crap out of this thing and watching videos cause they are really cool engines even before I found out how really cool they are (I like all old engines and working on them). I got a bit of some autistic traits so sorry about what you guys are about to read because I'm very curious and detail oriented and that's why I love engines... but also have to solve them or it drives me crazy haha. So I'm sorry about the long post.
So anyways, it's a 78' 900 (90hp 2-stroke: serial #4846442) with an ignition switch box, single coil, and distributor. It had sat for ages in this places front yard by the state lakes, I remember it from when I was young and still living back on the farm. So as you can guess the wiring harness is trash, which over in indonesia I normally make my own but this guy has agreed to buy a new internal and to remote throttle harness but I'm trying to diagnosis it to see if I need to order anything else cause my time is limited in the states. So while trying to diagnose the spark issue i've had it running that many times, come out the next morning and it's no spark. So I'd tweak some things and it'd run again, but this last time I'm not sure what happened but it's weird. I've checked grounds between all straps, cleaned/sanded all the switchbox/coil/distributor terminals, wrapped and cleaned all the wire connections and it was running fine but I didn't want to push it since I didn't know when the last time the water pump was changed but it ran good (minus carb leaks but not a problem for the spark issue). The last time I didn't have spark, and this is where it gets weird, is that I read that grounding is a big issue and I added a alligator clip from the switch box (lower screw hole on the body) directly to the internal wire harness ground on the side cowling. I turned it over and it started on 5 cylinders (#1 shocked the hell out of me even though I was holding the boot and ground the plug to the frame bolt). So I installed the #1 spark plug and tried to start it again and the starter sounded like it was taking a huge load and going slow but then it kicked off and ran fine and I shut it down. But my alligator clip connection got super hot and after trying to start it again it actually popped???? I did a quick check test on the switch box and coil and had spark (standard red and white terminals had 12.4v, detach distributor leads and coil high tension wire, bridged the lower two distributor side terminals and grounded the top and got spark from the coil high tension wire against the block) so think the switch box and coil are good but didn't have time to try the distributor trigger cause I thought it need to be pulled but have since found out otherwise cause you can just turn the engine by hand. I'm heading back to the farm tomorrow so will do that test but still got no idea why that ground popped and I lost spark.
So that's where I'm at now so I'm trying to figure out at much as possible before getting my hands back on it. I've read so much up on this but some info is conflicting so that's why I'm posting... my long post haha. In video's I've watched and articles I've read, it appears that if you do the switch box/coil/trigger test it will just run! Other's say that a failed stator or rectifier can also kill the spark. I've already disconnected the mercury tilt switch to rule that out even though when it was hooked up it was still running. I found one article saying there is a "momentary" kill switch on the push/pull shift linkage (makes it easier to shift into gears) that can cause failure but I haven't been able to check since leaving the farm so not sure. Other say starter solenoid as well....
So I guess what I'm asking, does anyone know a complete list on what to check or rule out if not connected to spark issue? What I know or have read so far in my 50+ hours of research is below but need help confirming:
-12v or so to the red and white connections on the ignition switch box
-do a coil test by the above mentioned (remove distributor cables, bridge two lower on switch box, ground top, remove coil high tension and spark to block)
-rotor cap or spring and carbon brush (trigger test, which i haven't done yet)
-mercury tilt switch
-bad stator??
-bad rectifier??
-bad starter solenoid??
-"momentary" kill switch on push/pull shifting cable??
-grounds
-does it have a different kill circuit even if I have 12v at the red and white?
-others?
And also, say with my ignition switch box and coil test where I did get spark, do the ever intermediately go out or are they either good or bad? Same for when I check the trigger tomorrow?
I need a beer guys and I'm sure you're already thinking wtf after reading all this, it just keeps me up not knowing the answers. But again, if I disconnect everything from the switch box and just do jumpers straight from the battery to the red and white will that take out any issues with the stator or rectifier as long as the trigger checks out tomorrow? Maybe I need many beers cause I can't stop thinking about this.
Cheers,
Nebraska
Nebraskan
So made it back to the farm, had to cut wood all day and bring it back but made a few videos as seen below. One is testing the ignition switch box/coil again and it still passes. The other is testing the trigger that still is not working from my understanding. From my understanding, the coil high tension wire should still spark even if there is a problem in the distributor cap/spring carbon brush/ext. correct? Because the cap and that is just to the park plugs (rotor problem/cap/wires), but the trigger should still send signal to the coil to spark to the ground from my understanding. So does that mean it has a bad trigger, maybe bad trigger plate I think people call it? I added extra ground connections again and isolated the ignition from the wiring harness by jumping the switch box straight to the 12v battery. So I'm still just trying to make sure what my problem is before having to order an expensive part if maybe there is another reason. So yeah, that's where I'm at from now but hopefully I'll have some time tomorrow to do some more checking. Thanks guys
Switch box coil test (passed for the 5th time):
https://www.youtube.com/watch?v=NQJSCkpgdpc
Trigger test... I'm assuming fail?:
https://www.youtube.com/watch?v=5MvYOaoeLNs
Chris1956
Your post is real confusing. Likely why you have no responses.
Take it back to basics. Disconnect engine wiring. Disconnect yellow wires from rectifier and insulate them. Jumper red and adjacent white switchbox terminals to battery. Ground motor and switchbox casing to battery. Now run spark test laid out on CDI website troubleshooting guide, with trigger disconnected.
If you have spark, the switchbox and coil are good. If not the switchbox is likely bad. Coils are almost always good.
Next, if you have spark, crank the motor with the trigger connected and see if you have spark. If so, trigger is good and you need to fix the wiring or get a new engine/boat harness.
Nebraskan
Yeah man, I hear you and get it as I stated before, you'd hate to see me with no filters cause this is me trying to make sense. those two videos i posted are for the switch box/coil test which passed, and the trigger test which I'm assuming failed as I got no spark but wasn't a proper bench test as to why i asked if there are any false fails due to other wiring or failed components. But trying to figure out why and that's why I gave the history of what I've done and saw. Still confused on why my ground strap popped even after checking all grounds (which were good), my gut tells me something else is wrong and if i just hook up a new trigger it will end badly for it or other components of the ignition system.
From my research this is a battery driven ignition with no fuses or protection, so I want to make sure that if I change out the trigger with a new one ($400) that this doesn't just happen again or burn something else out (switch box). So I'm trying to understand it all. Stator wires on this engine are **** and don't know about the rectifier either, but those two 40 year old systems (on paper are not needed for a battery generated ignition) but if I just do the normal test and show spark; might still wreak havoc on the ignition circuit or no since they share the same wires???? They are piggy backed onto the switch box through the rectifier/internal wire harness, so I'm still confused as to if that can cause a short if they are connected all together... or lets say if they (stator/rectifier/starter solenoid) **** the bed that the ignition system will not be wrecked by them?? Are they truly stand alone or can they wreck each other? Has anyone tried to add an inline fuse either way to protect the ignition system? At this point I figure it's better to run two 12v systems versus one cause I still don't know where my problem came from.
I've still been running down the rabbit hole on this one. Found this beauty after many many hours down the hole...:
https://www.youtube.com/watch?v=br_avtlPEd0&t=1202s
only 293 views at the time of posting this and 20 are probably mine but sounds like this guy knows a thing or two and like he said... I feel like a mushroom tester cause I still got no idea other then "replace it" but got no idea why. If any of you old merc guys are around I'm sure you'd enjoy it as much as I have. at 12:45 minutes is the model i'm dealing with and it fits the bill, still just don't want to fry a new unit or find out what the next weakest link is if I haven't been able to figure out the problem in the first place...
Chris1956
The rectifier and stator only serve to charge the battery. They should not be connected to the ign system. The rectifier will have two yellow wires and a brown wire for stator and tachometer. The red wire will connect to the battery cable in the engine harness. The rectifer will be grounded also. Original rectifiers were grounded to the case, internally, as they have only 3 connections visible.
If the rectifier shorts to ground it can discharge your battery. Disconnecting if from all wires and insulating them is fine for testing.
Not sure what to suggest beyond that. Make sure your engine wiring harness is connected properly and the insulation is good. A wiring diagram can be found at the max rules website.
Nebraskan
Hey, yeah, I get that they are only for charging, but if you look at the wiring diagram for this series of engine, one of the wires coming off the rectifier terminal is piggy backed onto the red wire going to the switch box that then connects to the battery positive down at the quick tatch (in this diagram it is below the switchbox picture if you follow the red cable) https://maxrules.com/oldmercs/Wiring/1966ona/50.jpg
So that one has me worried. Also, still not sure why the starter bogged down then blew the ground cable I alligator clipped from the switch box to the body. I had already put electrical tap on the + cable that goes from the starter to the starter solenoid so I don't think that would be it. If the starter solenoid goes bad can that short out anything too, or to the frame if it's cracked? Just something went weird and I lost spark for the last time so still confused.
The only other thing I can think of is some of the insulating seat material (not sure what kind of material it is but it breaks off in chunks) on the switch box terminals are cracked/broken. The insulation seats are still in their original positions, but one on the distributor side is half broken off so could it arc to the switch box? Don't think that's why the starter bogged down but curious anyways. I was planning on adding something to build the seat bed back up, but not sure what I'm going to use yet... any ideas what would work good? Maybe jb weld or some of that potting mix stuff? I was just going to do a rubber pad but I saw that the material is actually recessed into the switch box so might not be ideal.
Anyways, thanks a lot man
Chris1956
The rectifier needs to charge the battery. The red wire is always connected to the battery (and the switchbox), so that is the path to charge. Disconnect it if it bothers you.
The wiring diagram looks to be the correct one for your motor, BTW.
The starter should not melt any of it's cables. I would replace them, as they can rot out (to one or two strands) under what looks like good insulation. Voltmeters cannot detect this, but sometimes your fingers can feel the rotted bulge in the wire.
Starter solenoids usually do not short out. I have never heard of one that did. If they did short out they could connect the battery cable to ground causing a fire.
Not sure what you mean by insulating seat material on the switchbox. It was colored plastic with the brass terminal in it. The distributor should have three wires with ring terminals. If they break, you will have trigger issues.
There are two white and one black terminal on the switchbox. A white and a black terminals go to the distributor, and the other white is power to generates spark and that power originates in the ign keyswitch.
If you need to repair the switchbox connectors, I would recommend epoxy.
