Re: '79 115 knocking?!?!
Walker said:
mikesjohnson said:
if i take off the block below the carbs, i guess it would be called a reed block, will that allow me acess to the connecting rods. I would like to have a look inside before i put any money into it. thnx.
Nope, you have to split the crankcase to access the connecting rods.
Can you describe the knocking better. Those crossflows have a ticking noise, but I don't think you'd hear it unless the motor was running. Check your flywheel teeth and starter gear teeth.
i have what i would consider a great deal of internal combustion engine knowledge. I have been an auto mechanic for 9+ years, specalizing in heavy line (engines/drivetrains) i have heard many knocking sounds from enings over the years, but have never dealt with roller bearing knocks.
its a wierd noise. when it reaches compression (spun either way, by hand, not the starter) it will only make the knocking sound turned into compression, not away. in other words, when rocking the crank back and forth, it only knocks in one direction. when i let the cylinder leak down it doesnt make the the noise when it would pull the excissive rod bearing clearance up, from the other side of the crank journal. that may not sound very clear, so let me further explain.
when you have a rod knock in a non-roller bearing crank, you get two distinct knocks. one when the pistion starts its travel from BDC to TDC, when the at the bottom of the stroke, and one when turning TDC to BDC, at the top of the stroke. this noise is at about mid travel, when about 1/2 way through compression. you say that these motors are noisey, i think i may just be hearing the noise they make. with such even comppression, I dont think i have a rod knock, or even piston slap, as this should show up in a compression test, to some degree.
i hope this helps. i would like to avoid tearing this thing down just to inspect the rods, but it does need a few dollars invested before i get it running, and I would hate to spend the money, just to find out that i need to do a crank and a rod also, as this would have made the investment of a refurb more than the enigne is worth.
