rude92bayliner
- Joined
- Mar 31, 2013
- 3
Hey guys, new here...
ill start by saying i'm very unfamiliar with these engines, and boat mechanics in general.
i have a 1979 140hp rude and its in pretty good shape overall. i recently got the boat, and have only had it in the water a few times to do some testing and such. it was running well, had a drive engagement issue which i was able to solve with an adjustment of the shift control. when i dropped it in to test it, burned around the inlet a bit, and it started running really rough. i also noticed water coming out of one of the two holes below the cowl on the backside of the motor.
now when i try to start it, it runs for about 2 seconds and then hard stalls. its certainly only running on 3 cylinders, and when i checked the spark plugs the lower port cylinder plug had water droplets on it.
now firstly i have a couple questions regarding the head cover and gasket. when i removed that it was heavily blocked between the cover and gasket with what appeared to be salt build-up. is that what it is??
so now im looking for an area that the head gasket may be blown, except when i remove the head the head gasket appears to be in excellent shape, maybe even recently replaced (1-2 seasons) and doesn't appear to show any of the usual signs of being a blown gasket. im thinking maybe it could be drawing it in through the intake, but im not sure of the setup, and the common exploded diagram ive been able to find is not much help.
i dont know where else to start looking for any source of water in the cylinder. anyone have any suggestions for me because im basically at trial and error.
austin
austin
