Good afternoon,<br /> Im hoping someone here can point me in the rite direction.I have a 1979 mercury 1750 175 hp,over this past season Ive had an issue with it only running on 5 cylinders.For a time it would plane out and seem to run on all six after warming up but the last time out it wouldnt.I figured Id start with the basics checking plugs and wires,and I found that the bottom coil that wasnt firing was cracked and corroded.I replaced the bottom two coils,cleaned the plugs and made sure the wires werent broken or cracked by ohming them out.Needless to say Im still not getting spark at the bottom cylinder,I am getting 12v to the coil when the key is turned so I dont understand.<br />Thanks <br /> Dave
