'79 470 IO, looking for fuse block amperage on hydraulic trim motor solenoid
montejw360
I see there is a fuse block on the solenoid for the hydraulic trim motor/pump for the stern drive. can't find any markings on it, would like to know the amp rating. might upgrade it to something new. or at least get some sort of spare.
thanks
Bt Doctur
Re: '79 470 IO, looking for fuse block amperage on hydraulic trim motor solenoid
Valve Pressure Specifications
Valve Pressure
Up Circuit 2200-2600 psi
(15173-17932 kPa)
Down Circuit 400-600 P.S.l.
(2759-4138 kPa)
Electrical Specification
Pump Amperage Draw
115 Amps at
2200-2600 P.S.l.
(15173-17932 k
montejw360
Valve Pressure
(15173-17932 kPa)
(2759-4138 kPa)
Pump Amperage Draw
115 Amps at
2200-2600 P.S.l.
(15173-17932 k
wow. guess that's why it's directly connected to the battery with the fuse.
