Hi guys, been awhile but just got me a 85 Astroglass with a 79 75 hp on it. Guy said it ran fine last year have receipt from where he had it serviced, carbs rebuilt, new gas lines on motor and to tank. Took it home cleaned it all out, drained the fuel and replaced with 50:1 mix. Hooked a hose up, squeezed the bulb and sprayed some gas mix in the carbs and turned it over, started and then died repeated two more times fired up but runs rough and doesn't seem to be getting up to WOT. Took it to the lake fired it up it idled but still rough backed it off the trailer and took off slowly and it was going but never got up to WOT. Went a 100 yards and died, restarted and never would get past idle speed, turned around and went to the ramp and never got it to go past idle without dieing. I'm thinking the carbs needs cleaning? Any help would be appreciated. Also looking for a good used prop at a reasonable price. Will get back with the prop details when i get home this afternoon.
Thanks
Thanks
