Re: 79 chrysler 140 won't start
I went and messed with it more tonight, got a freshly charged battery, and a fresh tank of 93 with startron fuel stabilizer in it, also replaced my spin on water separator/filter with a new 10micron one.
I checked my pumps, both gaskets and diapgragms looked good, I'm going to install new ones tomorrow..they are cheap..
I tried pumping the ball while the engine ran, didn't seem to help at all.
It started up after a little choke and ran for a few seconds and died. Started up again, seemed to be running good then it backfired and was running but not on all 4 and then died out.
I took off the fuel bowls to make sure the floats were right. The gas doesn't have any crud in it. Either way I put the tube on the carb cleaner and sprayed around a little.
Fired up again with a nice puff of smoke and ran again maybe 2 minutes, not on all 4 though, it coughed a little and jumped up on all 4, then it died.
and no....I don't have the filter between the pumps and the carb, I had one, but had taken it out during troubleshooting last year, seemed to run better w/o, I am screenless though, I guess I'm putting all my faith in the tank screen and the fuel water separator filter.
Is the spark from those CD boxes an all or nothing thing or do you think it may be getting too weak to run properly?
