Ok here I go, This motor was running pretty good, but did not run as strong as it did when I got it. I decided to install new pistons and rings and just basically go through the motor. The problems started early when I broke a bolt off in the top of the flywheel. Decided to drill the bolt out and retap. Well, Once I got the flywheel off, I realized I also drilled the Timing Stator, Low speed, High Speed or something like that Coil. There is one solid coil on one side and two smaller coils on the other side on top of one another, well it was the two together. It just nicked the side of it but still. Got the motor back together and I have no spark. What do I do??? Also, In the junction box, I have one green wire from the C.D.I with no where to hook it. I have a O.E shop manuel and it shows it going to the N.S.I but this motor doesn't have and N.S.I, everything is color coded but no other green, what do I do with this wire????? Please Help
