79 Evinrude won't shut off with key
nvanzee
I have I believe a 79 Evinrude 25hp. Worked fine last fall. Now doesn't shut off with the key. Have to choke it to get it to stall. I replaced the ignition switch but that didnt fix it. I checked both wires labeled M at the ignition. Both are grounded with key on or off. Have continuity between them only with key off. I have a good ground on the motor and the outboard housing itself. Don't know much about outboards. Anyone have any suggestions on what to check next?
Vic.S
I don't think it will. The 1973 to 1976 models have points ignition
A 1979 model has cdi ignition
This diagram for 25-35hp 1982/83 models will be more like it
Check the continuity of the two wires on the "M" terminals of the switch
One ( black, ? ) should show continuity all the way to the motor ground.
The other ( black/yellow ?) should have continuity to the Cdi unit.
There may be a bad connection through one of the multi-pin connectors.
nvanzee
Thanks. I ended up finding a spot in the harness that had rubbed through
