Re: 79 Johnson 115 - Lower unit STUCK - Now What?
So this all started because I had milk in my lower unit. Knowing it needed to be addressed sooner than later I thought, I've got some time now might as well. First step was to remove the lower unit for inspection and pressure/vac test to find source of leak. Well as shown by the title and my first post in this thread, she is stuck good. I tried all of the conventional wrestling moves but still no go and knew in the back of my mind I was going to have to get this motor upside down.
Yesterday was Day 2 of the saga - I started by ordering a lower unit seal kit and water pump kit from TCMarine since they were the only ones who could get me the parts by Wednesday. Not having the OEM manual and not being able to confirm the source of my leaky gearcase I needed to order nonetheless - so hopefully I've got the right parts coming.
Anyway onto the engine removal. Yep this is a serious PITA for a 30+ year old boat and motor that has never had anyting removed - I had visions of bolts snapping, plywood ripping, etc. My approach was nice and easy, don't force anything and work with the ol gal instead of wrestling if at all possible. 11pm last night finally got the motor control lines disconnected, power tilt trim cables disconnected, steering linkage removed (had to do that in conjunction with lifting the motor off the transom - despite the trim tube being gunked up a little gentle pursuasion freed it up). Went to bed after that as my brain was fried so I free hung the motor back on the transom overnight.
Woke up this morning and immediately went to work designing an engine stand that will alow me to flip the motor 180 degrees and then allow me to hoist it by the petard (aka lower unit). Off to build the stand and then will dump a can of PB Blaster in to do its work (along with gravity) to free up the drive shaft from the crank housing.
FEDEX tracking ETA is Wednesday 5pm PDT so that gives me a little over 24 hours for the PB Blaster to do its thing. Need to reassemble Thursday and then hit the water Friday. At least that is the current IF EVERYTHING GOES ACCORDING TO PLAN philosophy which thus far has proven wildly inaccurate.
I'll post up some pictures once I've got her all done in case it might be of assistance to others in the future.
Wish me luck.
