Re: 79 Johnson 115 rpm
ok here's what I've found. I swapped the coils between 1 and 2. the 1, is the newer style. it doesn't have a ground wire, it has the strap for the bottom bolt to hold it over tightly against the head. The paint wasn't removed for it to get a good ground. I made sure on #2 I removed the paint to ensure a good ground. Also, the orange wire going to #3 had a bare spot scraped in it. I sealed that up, gotta love that liquid tape in the spray can.
fired it up, now here's the thing. Since I've had this boat and put it in the water, even the first time out when it ran ok, I could never start it, even when warmed up, without pushing the key in to activate the choke, and raising the fast idle lever. This time, it fired up with no choke, and the idle lever down. shot a good strong blue lightening bolt on both, so I'm of the mind it wasn't grounded good, that would do it, right?
I do have another issue I would like some suggestions for. This thing will NOT go back to idle set screw against the block. I put it in gear to see what it was going to idle in gear at (I do know I really need to put it back in the water again to test that btw) and revved it to about 16-1800, and puttting it back in idle, it stayed around 1200, but the screw didn't go back to the stop. I shut it down, disconnected the cable end completely, pushed the screw back to the stop, adjusted the trunion knob to line the hole up with the stud, put it back together, tightened everything down. started it back up, revved it, back to idle, same thing. The idle screw will NOT go back against the block. not sure what else to do or check. is this spring loaded? any and all suggestions and advice greatly appreciated!
