I have a problem i'm having a problem figuring out. O.K. last year, i was turning 5200 rpm @ 53mph, then the impeller went out and no alarm, engine heat ceased up. I tore the motor down and sure enough melted #2 piston, cleaned up the head, had the #2 sleeved (was scratched really bad) and bored .2 over along with the rest of them. All new pistons and rings and while i had it tore down i rebuilt the carbs. Now the motor starts and idles great, smother than ever, runs great all the way up to 4200 rpm. I have about 5 hrs on the break in and trying to figure out why when i go full throttle i can now only get 4200 rpm and about 42 mph. I've done a link and sinc adjusted the timing per the reeves method (it had changed alot from where it was set before) all with no change in wot rpm. I've checked the spark will jump 7/16" on all 6. Checked the compression and got between 94 and 105 on all 6 ( with only 5 hrs on the rebuild, i'm assuming the ring not seated yet). Any suggestion as to what to check now?
