'79 Johnson 70 hp OB, Power T&T Failure
Glastron Frank
Pressing T&T thumb switch up or down results in click noise from respective up or down control relays/switches? located in small black plastic box mounted on wall at stern. Nothing more, no whirring noise from lift motor. Inside black box, all connections to terminal bar and relays look dry and tight with black plastic protective coating. Boat spends most of time dry docked and covered outdoors. Last time used was August 01. Motor placed in down position for max. water drainage from foot. Light oil residue around base of starboard stainless steel piston.
