Re: 79 johnson squeek and caugh
turn the knob to the rich side! add more oil to your fuel! give it as much rich fuel as it will take without bogging down, rich fouls plugs, lean kills engines. if going hard to the rich side at the throttle settings you were describing the problem at, doesnt seem to make a difference, go easy...slow down , take your motor home, and rebuild the carb! tons of excellent info here on the procedure....the right way!
