DrWiffel
- Joined
- Mar 8, 2010
- 102
I?m currently getting towards the end of a rebuild project and am at the point where I am connecting the throttle/shifting controls. Before I connected the controls I wanted to give it one more test before I bolted them in. I can shift the motor into forward, neutral, and reverse, but the throttle was having issues engaging. I can freely move the throttle cable with the neutral throttle lever with no issues. I made some adjustments to the shifting cable with the black knob (no idea on the proper name) that is at the motor end of the cable and was able to get movement to full throttle after that. The reverse at that point would still shift but I can?t seem to get any throttle from it.
I?m at a loss here, and can?t figure out what could be causing this issue. I did some searching here and wasn?t really able to find anyone else that had had the same issue. Which makes me thing that it might just be something easy that I might be missing (or so I hope).
The serial number for the motor is 5128781
Thank you in advance for any help that you might be able to bring me. If any picture or other information is needed please let me know.
Thanks,
DrWiffel
Thanks,
DrWiffel
