79 small block 350 OMC I/O needs fuel pump[
taxijim
My question is whether any fuel pump that fits a small block GM 350 engine for that year can be used - or is their something "special" about the much pricier "marine" pump the catalog is calling for for my cabin cruiser sterndrive
Fishermark
Re: 79 small block 350 OMC I/O needs fuel pump[
The marine fuel pump has safety features that keep you safe when it leaks. A "regular" pump does not have these features, and will leak fuel into the bilge. That is an explosion waiting to happen. Go ahead and shop around for the best price - but stay with marine.
Ayuh,... I Agree,... The fuel system is Not where you cut corners...
jtmarten
Nope. Spend the $110 on a marine pump.
taxijim
thanks everyone for the input. I have ordered the marine pump and awaiting it to be delivered. On further investigation, I also noticed other differences in the standard non-marine fuel pumps for that engine model size and year and the most noticable difference was the gallons per hour on the non-marine are only 40 as opposed to the 60 gph on the marine pump. I also purchased and have already installed a water seperating fuel filter for my boat (my previous engine had one installed, but when I replaced engine last year, it didn't have one). I am curious however about how often one should change the filter on this one, as it is not posssible to inspect the contents of this filter like the old screw on can one i used to have. This filter looks just like an oil filter and the whole thing just unscrews and is discarded when changed. How do you know when it's time to replace it ( other than engine malfunction, of course )?
Ayuh,.... Annually, or when Water is suspected...
zbnutcase
Once a year on replacement.
