79 whaler rub rail question
dsujen
I have a 1979 boston whaler 15'3" center console that has a bad rub rail. It appears to be riveted on. A lot of the rivets are pulled out. How can I fix it? Is it riveted to wood or fiberglass?
Quick3201
Look on this site for replacement rub rails. Fairly easy, just a lot of drilling. I used a molded hard rubber rail with insert to hide rivets. Measure according to order sheet and try to get a very hot sunny day to let the material heat soak out side, easier to work with.
