7HP wizard has no spark
gatemindr2
I just got a jon boat with a 7hp wizard outboard and it has no spark what could be wrong any help would be great. It is a western auto wizard. I just want to get it running. Model number is ESK6602A37, serial number is 3B 400 644, also on this tag it has Western Auto. I have tried to get the flywheel cover off but I can't. Does anyone know where I can get a manual for this outboard so I can rebuild it, if I can find parts. Thanks gatemindr2@yahoo.com
gatemindr2
Re: 7HP wizard has no spark
update got it started and it does run, pulled foot what type lube should I use it the foot and does anybody know where I can buy a water pump. Thanks for your help. gatemindr2
steelespike
I believe that is a 72 Eska built motor.Use regular outboard gear lube.
Try discount marine or certified parts corp for parts These have a poor reputation See if water mists out the relief holes on the leg. Keep an eye on the mist try to be sure it seems to operate right before spending too much on it.
alangf
This is not an engine that warrants spending much money on. My limit would be about 25-30 dollars.
