I've got an 8.2L DPX 415hp with a cracked block and the longblock price is way higher than I expected so I was hoping someone here had some alternative options. All the technical data is posted below. I was wondering if I could go with a 8.1L without running into huge headaches. I've found some 8.1 for much more reasonable rates. Or, if anyone here has a 8.2 they want to sell me I am in the market.
Technical data
Engine DPX415XBYDCE
Production period 1997-1998
Operation 4-stroke
Cylinder configuration V-8
Bore (mm) 113.5
Stroke (mm) 101.6
Compression ratio 8.81:1
Displacement (litres) 8.23
Power (hp) 415
Max engine speed (rpm) 4600-5000
Technical data
Engine DPX415XBYDCE
Operation 4-stroke
Bore (mm) 113.5
Stroke (mm) 101.6
Power (hp) 415
