Re: 8 foot quicksilver inflatable with 15hp
We have supplied and Tested many Zodiac inflatables and ribs. Everything from a 3.5hp on a 8.0" to 240HP Hamlton diesel on a 24' (Navy boat).<br />I invented Smart Tabs origionaly for a 10' soft bottom Zodiac, with a 9.9 two stroke. The 15'HP was the same motor except for a throttle linkage part. This means that the low end torque is the same as well. HP is developed in the higher RPM range. <br /><br />The Hoda is going to be much quiter, but harder to get on plane. The 15HP will probably no weigh too much more, and will plane easier. In either case the comfortable cruising speed on this boat with not too much of a chop, will be about 8 to 10 MPH, although the boat will get to about 15 MPH with the Honda and 20 with the 15. In either case both getting on plane and holding it at 8 to 10 MPH will be nearly impossible. You will need to be going at least 14 to 15 MPH with two people.<br /><br />The bow rise will be horrible at slow speeds with either motor. Top speed will be a problem as the boat will be difficult to handle. Frankly they handle like crap. Most people will put a hydrofoil on the motor, but other than some minor assistance with planing they can cause more handling problems than benefits.<br /><br />As for the choice, the motors will weigh about the same, so moving things arroound will be equal. The added HP will be nice if you try to cruise with a larger load. If the 15 runs nice, I would lean that way too. If you get water in a four stroke engine it's a goner. A two stroke can be run with some extra oil for a few minutes and your good to go.<br />Fuel economy on a motor of that size is a none issue.<br /><br />Check into Smart Tabs if you buy one and realy want to have a nice clean, smooth running tender.
