8 hp 4 stroke that can take 90 deg swing to side
I have a 24' cat on the west coast of Aus. I'm looking at a replacement oboard which would be able survive a bit of a dunking being attached to the rear beam of my sailing cat, is not too heavy (current motor 35kg or 77lb) and is able to cope with being swung 90 deg laterally on a bracket so that the leg is parallel with the rear beam. THe hulls are fine so I can't take heaps of weight and I would need around 8 hp at least.
JB
Re: 8 hp 4 stroke that can take 90 deg swing to side
Moving to General Outboard
rickdb1boat
So it is still getting is swamped even when tilted up? Is that the problem? Correct or am I missing the point? I don't know of any that swing to the side, although there may be a "Jack Plate of sort" that would do that.
